unburned fuel causing misfire, what is it?
I have a slight problem with my engine misfiring at high rpms shifting into second hard. I recently put in new spark plugs, but not my wires. I think it is the wires that is causing the slight misfire. (it's not any of the cylinders because I did a compression test and all were up there.) If anybody else has any suggestions please reply to this post!<P>Tooprime- 92' Blaze Red GS<P>[ October 05, 2001: Message edited by: Tooprime ]<p>[ October 05, 2001: Message edited by: Tooprime ]
Re: unburned fuel causing misfire, what is it?
when were your wires last changed??<BR>I know when I went to change the plugs about a year ago, I had the clip that normally goes around the plug.While the rest of the wire was in my hand. Took me a better part of an hour to get the clip and plug out from the back bank. I had re-attached the clip to the wire and found that I had lost some performance.....especially when accelerating.<P><BR>cheers,
What type of spark plugs are you using, and are you sure that they're the best for tyour car? <P>If you're using Champions, that's your problem right there, I could tell your stories about the crappiness of those plugs.
I'd recommend Bosch +4 Platinum plugs and either NGK or Magnecor wires...nopi.com sells NGK's for around $70...<P>did you change your cap and rotor??
Thanks for all your replys, I am running bosch platinum right now for the time being. The plugs haven't been changed probably for 75,000 km. When I had the old plugs in my car, it would not do this, only until I put the new spark plugs in. Could it be that the plugs are toast and not putting enough voltage to the spark plugs.<P>Tooprime- 92' Blaze Red GS
I'd change 'em...it can't hurt any
maybe a stupid question but maybe you have rev your engine too high in the redline and got the cutoff...know what i mean ...?<P>i really d'ont think its that but...<BR>good luck
Friends don't let friends drive stock.
I have never redlined this car, sorry!
- Custommx3
- Site Administrator
Check the gap, you could have messed up your wires as well when taking them out to install the new ones.
Also, try resetting your ECU (unplug your battery for about 10-15 mins)...that just solved one of my problems
replaced my plugs and reset the ecu and the problem is still there. I am now going to take the spark plugs out and re-check the gapping. (or maybe I have a faulty spark plug)
can someone tell me how you can tell your engine is misfiring... i've asked this question so many times and i still dont know!
Shaun Newman
Checked the gapping, which was set to standard and the problem is still there. I know I have a faulty O2 sensor that may be causing the problem. Or could it be a leak in the exhaust.
How do you know if your o2 senser does not work?
The best way is to probably get a code scan done to tell you which sensor is faulty. Ex: O2 sensor.
