Engine knocks-help needed
Hi!<BR> <BR>Car: -92 V6.<P>Problem: The engine ticks/knocks. I have tried to change from syntetic to ordinary mineraloil. The sound stays the same.<P>One mechanic told me to buy new valvelifters.<P>Is that the problem?`<P>
Angel
Re: Engine knocks-help needed
I have a ticking noise from my engine as well...David Coleman told me that it was my HLA's, and that all K series engines do that after a while. He recommended that i use 5w30 oil, which i did, and it got rid of my noise<P>------------------<BR>~'94 GS (Creek Blue Mica)
Can you tell me what HLA's are?
HLA - Hydraulic Lash Adjuster<P>This is the device that sits atop the valve and that the cam lobes ride on. One HLA per valve = 24. It's the same concept as a hydraulic lifter in a pushrod engine. It keeps you from having to adjust valves as with a mechanical setup like on the 240/260/280Z's.
Thanks, I got a nother wrinkel today! <P>
you might also want to check your timing belt and your hydraulic tensioners... i just got mine replaced and my car is so quiet at idle speed that i have to step on the gas to know it still runs...to do that it costs around $ US 500. yikes !<P>------------------<BR>Frenchguy0<BR>'92 GS Emerald Green<BR>crenia@hotmail.com
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by appe:<BR><STRONG>Hi!<BR> <BR>Car: -92 V6.<P>Problem: The engine ticks/knocks. I have tried to change from syntetic to ordinary mineraloil. The sound stays the same.<P>One mechanic told me to buy new valvelifters.<P>Is that the problem?`<P></STRONG><HR></BLOCKQUOTE><P><B>Knocking</B> and <B>ticking</B> are two entirely different symptoms.<BR>Ticking is common on the V6 and can usually be cured with a motor flush and good oil.<BR>See my WEB page for information on the HLAs and the exhaust cam spring noise problems.<P>Knock is an ignition/fuel octane issue or a problem with bearings in the short block.<P>Where is the noise coming from <I>exactly</I> in the motor? (listen closely near the valve covers)
I notice a ticking about once every month or two. I check my oil, and it's low. Make sure you're up to date on an oil change, and your crankcase is filled up. That should help with ticking.
Taylor<P>1995 Chevy C1500 Dark Blue<BR>* 305 (5.0L V8)<BR>* Hypertech Performance chip<BR>* Dynomax dual exhaust<P>SOLD: 1995 Dodge Dakota Sport - Flame Red<BR>* 3.9L V6 - 175 hp<BR>* Flowmaster dual exhaust<P>I Miss my MX-3:<BR>1992 MX-3 GS Blaze Red
i have change the springs cam and now it run like new !<BR>
Friends don't let friends drive stock.
I had them change the CamShaft Friction Gear Spring...$1100 later it runs like new.
$1100 later it SHOULD be new hehe
Dont stress at me, its not my fault your slower...
...keep in mind $1100 is like just over $700 USD.
