Engine Problems
Engine Problems
Recently I was driving down a highway and slowed down a bit to let some pass by and as I steped on the gas to get back up to speed my engine started to act like i was running out of gas but i had a full tank so I pulled over and could not get it started back up. If any one can help with any suggestions on what is wrong please reply. Walking two miles in 105 degree heat to a gas station in the middle of nowhere is not fun.
92RedGS
<BR>I'm Sorry, Officer, I didn't realize my radar detector wasn't plugged in. Say aren't you the guy from the Village People?
white fish
Re: Engine Problems
maybe distributor<BR><P>------------------<BR>Clear White 2.5L GSR
Bri94GS
Re: Engine Problems
Either that or your alternator....u clean anything under the hood lately??
- SE-Man
Re: Engine Problems
I've had the same prob, but i could start it if it was floored, but it then would die again when the RPMs droped..... I've still not got it fixed.<P>------------------<BR>Thanks,<BR>Teri<BR>'93 MX-3 SE
Frenchguy0
Re: Engine Problems
Once my alternator belt broke and my car just died on the Highway. It would start with jumper cable but die 2 minutes after. I had to change alternator belt (US $15) and my battery. <P>------------------<BR>Frenchguy0<BR>'92 GS Emerald Green<BR>crenia@hotmail.com
Re: Engine Problems
the problem is i haven't cleaned anything under the hood, my belts look fine, and when i try and start my car it turns over and sounds exactly the same as normal but it won't start.I'v been racking my brain over and over agian and all I can think of is maybe there is something wrong with the fuel getting to the engine(fuel pump or something)<BR>This is just a guess i'm not that mechanicly inclined with indepth engine parts.
92RedGS
Re: Engine Problems
I recommend that you try to get someone to give your car a boost to see if it will start.... if it does start then it may be your alternator or battery! If it doesn't start.... try checking your distributor!
jonnybpimpin
Re: Engine Problems
well the exact same thing happend to me and my dad to his mazda truck. all it was . was the battery . and some fuel filter. <BR>this happend in the winter after a long drive. like a 5 hour drive. <P>if this helps at all i donno. <P>jonny
- cjthor
Re: Engine Problems
Hey man,<P> Pull out one of the spark plugs and try and start the motor. If you can smell gas in the cylinder you are ok. If not check the fuel pressure regulator or the fuel pump.<P> Jarid Perry<BR> 94 Blaze Red RS<P><BR> <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 92RedGS:<BR><B>Recently I was driving down a highway and slowed down a bit to let some pass by and as I steped on the gas to get back up to speed my engine started to act like i was running out of gas but i had a full tank so I pulled over and could not get it started back up. If any one can help with any suggestions on what is wrong please reply. Walking two miles in 105 degree heat to a gas station in the middle of nowhere is not fun.</B><HR></BLOCKQUOTE><P>
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
Re: Engine Problems
Well today i changed out my fuel filter and i still can't get it started so tomarrow i think i'll take the fuel line off the filter and see it the fuel pump is still working. before i do that though i wanted to ask the board if anyone knows if there is a fuse for the fuel pump. also i wanted to thank you guys for the help and i i do finaly get the problem fixed i'll post the solution here in case someone else has the same unfortunate problem.
92RedGS
mazdamaniac
Re: Engine Problems
The problem is almost certainly your distributor.<P>------------------<BR><B>Jeff Abrams</B><BR> jeff@mazdamaniac.com <P><B>SUPERCHARGED</B> 2.5 liter 1993 Mazda MX-3 GS <BR> <A HREF="http://www.mazdamaniac.com" TARGET=_blank>http://www.mazdamaniac.com</A> <BR>Normally aspirated 1997 Mazda MX-5 Miata
mendel00985
Re: Engine Problems
There's a fuse for the fuel pump in the cluster of fuses in the engine bay; I think it's a 10amp fuse but you can check the cover.
Re: Engine Problems
To Jeff Abrams<P>Is this the problem that you discribed under the distributer page on your web site. if so should i just get a new distributer and put it on or what would be my best course of action from this point because i'll try anything to just get my car running again.
92RedGS
Bri94GS
Re: Engine Problems
Make sure all your spark plugs are in order, and that they're all connected tightly. Maybe try changing dist. cap/rotor before buying the more expensive peices. Other than that, I would think it was your battery or alternator....did you try poppin' the clutch to get it started? Or do you have auto?<P>------------------<BR>~'94 GS
Re: Engine Problems
I'd like it to be a five speed but it's an auto and i know the problem isn't my battery because everything works when i turn the car on. when i try to start the car it turns over but won't fire up like its supposed to. It fired up the first time i tryed to restart it on the side of the highway but felt like only two out of the six spark plugs where actualy sparking and was knocking really hard.
92RedGS
