close ratio gear box
anyone have any idea on what mazda close ratio gearbox will bolt right on to the gtx engine for the az3
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
AUTOZAM AZ-1
might but i doubt it.
What? You mean the same engine in the Az1 and the Cappucino is a snowmobile engine?
