wining
Posted: August 15th, 2004, 3:42 am
by 93-Spec-Edn
Hi
I just installed a sub and an amp and At low volumes as i accelerate there is a wining noise. any ideaS?
thanks
Re: wining
Posted: August 15th, 2004, 3:50 am
by 2fazed
That could be alot of things. Most likely a ground issue. Maybe a ground loop isolator might work for that.
Re: wining
Posted: August 15th, 2004, 4:02 pm
by Typhoonk
make sure the amps body is not screwed to anything steel in the car. Mount the amp to a peice of wood then mount that to the car. Ground the amp to a flat steel panel, not a bolt that is already there. also get a deck with high voltage pre-outs that would make almost any install fool proof.
good luck
Re: wining
Posted: August 15th, 2004, 7:20 pm
by endocyc
Did you by any chance run the RCA cables & Remote wire along the same path to the amp as the POWER wire. This will cause noise aswell.
Re: wining
Posted: August 16th, 2004, 12:24 am
by 93-Spec-Edn
Yes i did that. I also grounded the amp to the bolt of the rear seat. How can i separate the 2 wires? I will try to fix that and see if it works. I will post an update.
Re: wining
Posted: September 17th, 2004, 1:46 am
by hondah8er13
just run the wires on the opposite side of the car, and get yourself a self-tapping screw and screw it to a SAFE spot in the trunk, don't forget to scrape the paint away from the area around the screw so that it makes good connection. hope that helps
Re: wining
Posted: September 19th, 2004, 12:55 am
by Typhoonk
Another good tip -> Don't use the factory ground for the deck. Run your own ground wire, and ground it to the firewall. Get's rid of turn-off pops, and weird ground loops.
just another prevention
(and try to keep the wire short)
Re: wining
Posted: September 19th, 2004, 9:36 am
by fry_81
new grounding wire, hmmm, maybe i should try that with mine. thanks alot.
