amp
Posted: November 19th, 2003, 8:58 pm
by steven
were is a good place to mount my amp? i was thinking to put it on the seat but my amp dosent have any mounted brakets so i can put it on the seat?
Re: amp
Posted: November 19th, 2003, 9:13 pm
by pipes
Depends if you want to see them.. I have a 4 channel mounted under my driver seat and a 2 channel mounted under the passenger seat.. I like to keep it nice and clean and still have a boot!
Re: amp
Posted: November 20th, 2003, 12:11 am
by steven
hey can u show me a pic?
Re: amp
Posted: November 20th, 2003, 2:19 am
by pipes
I possibly could but It would require me reoving my seats..
Trust me on this Take your seats out of your car if you are going to wire anything up.. it is alot easier...
All you need to do is run Your 4 guage power for you amps from the battery, under your carpet and to where the amp will sit..
Ground your amp to the seat bolt.
run RCA's from your deck to the amps then run some good uality speaker cable back to your speakers..
If you remove your seats man you will see that there is a fair bit of space under there.. Just get a airly good quality amp that is not HUGE!
Good luck.. If you really need.. I doubt you should though ask again later!
Good luck
Re: amp
Posted: November 20th, 2003, 3:07 am
by BumpNGlow
that's a fairly small area to work w/ (under the seats) and there's also very little room for ventiliation. It's not usually recommended to put amps down there.
What amps do you have that don't have mounting brackets? I thought every amp had some type of mounting bracket on it.
Re: amp
Posted: November 20th, 2003, 7:41 pm
by Sam Baker
i have my 4 channel amp under the passenger seat as well.. seems to work fine actually! i put cardboard under it, and theres about 1-2" room above it. as far as adjusting goes, i pretty much set it to how i liked it first and then left it there. :p haha if u need a pic check out the "audio" page on my site. good luck!
~ sam
Re: amp
Posted: November 20th, 2003, 9:11 pm
by steven
i have a crunch amp
