ground points? please help.
Posted: September 20th, 2003, 9:31 pm
by PTBNL
The "Ground Points" section of the online shop manual doesn't seem to be working.<p>my power locks, dome lights, and head unit are among the things not working. Where at the ground points that I should check?<p>I don't know anything about wires, so any help would be appreciated. Thanks.
Re: ground points? please help.
Posted: September 21st, 2003, 10:32 am
by lakersfan1
I knwo the radio grounding point is in the center console. I don't believe it is a shared point with any other components. I wouldn't suspect the ground as a problem point anyways unless you went indescriminately cutting wires in your car one day. You did check the fuse box, right?
