so i just bought 2 10" volfenhags anyone know how these speakers handle? they sound awsome but just wondering if anyone had any experience with them <p>here are the specs:<p>ZX 4710DVX Specifications: <p>
Magnet: 160 oz. Double stacked Ferrite magnets
Frame: 5 spoke Die-cast aluminum basket
Cone: Reinforced aluminum curvilinear
Surround: Oversized buytl rubber
Spider: 2 Flat ultra excursion
Power handling: 400 watts RMS, 800 Watts Program (conservative)
T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented
Double damper magnetic motor assembly
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
Voice Coil Diameter: 2.2"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms each coil
Frequency range: 20 Hz-1.1 kHz
Fs:32 Hz
QTS:.461
QES:.541
QMS:7.62
VAS:35L
SD:.0346M
SPL:89 dB 1W/1m
Xmax:16mm
Mounting Depth: 145 MM
Mounting Hole Dia.:246 MM
Net weight: 21lbs
VolfenHags?
VolfenHags?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Re: VolfenHags?
hey i just bought 2 12" compition volfenhag subs. and i hear that they can put out some awsome bass and last a long time.
<img src="http://www.inuyasya.com/A-HASIRU-S.gif" alt=" - " />
Re: VolfenHags?
my volfenhag amp lasted years and put out good numbers until it was stolen. ![Mad :mad:](./images/smilies/icon_mad.gif)
Shaun Newman
Re: VolfenHags?
sweet see i was worried because a few guy around here that are big in sound were putting them down on pyramid/legacy level, but i figured it was becase they are a new company and do not have a great rep yet
Re: VolfenHags?
just be warned.... They are NOT the kind of subs I'd use for "high" numbers. Friends of mine have purchased them with the only intention of blowing them up.
FOR SALE, AS A PARTS CAR
Re: VolfenHags?
Dang i wish i had enough money to buy subs just to blow them.
My Cardomain site
My Cardomain site
Re: VolfenHags?
well i have my compition 12's set into a Q-logic box and is being powered by a Infinity Perfect 1200 wat amp. i tested one sub w/ my gain turned up 1/4 and my bass boost off and it sounded so loud it wasnt funny. it hit low and hard. it is the cleanest sounding sub i have ever heard. i cant wait to get my deck and hook both up.
