Problem with Alarm
Car Stereo/Alarm Discussions
DVH
Problem with Alarm
Post by DVH »
K, i installed this alram my self and I'm not really that great in this area, i know some of my sh*t, but not a specialist or anything...lol<p>K, so when u hit ur alarm to go on or off, the lights usually blink , or if the alarm is set off they blink, but now, for some reason they don't??? They used to always blink when i hit the alarm. I checked the wire, but it was fine...what esle can i check?? Are there any fuses that could affect this ???<p>Also, if i get fog lights and just hook them up to a + and - wires, will they work?? I want them so they come on when i put my lights on at night.<p>thanx for the help guys in advance :D<p>[ March 16, 2003: Message edited by: DVH ]</p>
Derek Van Horne MX-3.com Member # 33
94 MX-3 Silver Stone Metallic CAR is SOLD
Car Domain Web page MX-3
Car Domain Web page SRT-4
mzdspd
Re: Problem with Alarm
Post by mzdspd »
most good fog lights come with the stuff to make em come on with ur headlights. as for the alarm try resetting it if that doesn't work its a fuse or a wire
DVH
Post by DVH »
thanx, for the info, i know its not a wire, so it must be a fuse.....i'll try lookin on tuesday<p>As for the foglights, here 's what i got, a + and - wire that are free and not being used....they used to be used for my side markers, but pakfiefer does not make a spot of the side on their front bumper, so like i said i have + and - wires. Can i just hook these to the fog lights and they should work right?? :shrug:<p>[ March 16, 2003: Message edited by: DVH ]</p>
BumpNGlow
Post by BumpNGlow »
sure -- there MIGHT be a power limit so be weary of that -- a relay just to be safe?
FOR SALE, AS A PARTS CAR
Hex3
Post by Hex3 »
The white wire(most alarms) that comes of your alarm hooks up to the parking lights. That should have a fuse on it. It might of grounded out and blown a fuse. to make sure that there is nothing wrong with ur alarm, check it with a meter to see if when u arm the alarm the white wire sends voltage to the parking lights off the alarm!!!!!
You can also use a test light...
2.5 KL-ZE, BBS rims, I the front i have to falkin Azenis, Intrax Springs, CM Stage 1 clutch, and Fidanza flywheel, Pacesetter short shifter, Tociko Blue Struts, Sparco Steering Wheel, Yellow Top Battery
Alpine Type R Subs 10's, Alpine 2 Channel Amp, Alpine 4 channel
Amp, Alpine Alarm,Alpine Headunit
14.8 @ 94.2(with vaccume lick)
DVH
Post by DVH »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Hex3:
<hr></blockquote><p>tried it and there was no power at all goin through when i hit the alarm......no light...so does this mean its probbaly a fuse?
Hex3
Post by Hex3 »
Follow that wire to the alarm brain see if that fuse is blown, if it isnt then its something wrong with the brain!!!!
DVH
Post by DVH »
Follow that wire to the alarm brain see if that fuse is blown, if it isnt then its something wrong with the brain!!!!<hr></blockquote><p>i'll give her a go tomorrow and keep u all posted! thanx fo rthe info!<p> :D
DVH
Post by DVH »
All fixed, thanx for the help guys, greatly appreciated, it was just a fuse.....later :D
Return to “Car Stereo/Alarm”
