MECP
Posted: April 7th, 2002, 11:49 pm
by -=deathtrap-mx3=-
i know some of you guys are installers. how much time goes into being certified?
Re: MECP
Posted: April 8th, 2002, 12:25 am
by MX-3 Extreme
Well I am going on my 8th year as a certified install with a First class MECP which is the second level out of three certificates. I also have an Ontario Automotive certification for Install Automotive accessories such as remote starters and alarm systems ect. I have been through training about 7 or 8 times a year buy vendors and other certified installers.<BR>YOu must renew your certification every two years by law.<P>Killermx3
Re: MECP
Posted: April 8th, 2002, 12:26 am
by Da_Wiggy
depends on how much you already know. getting your mecp certification can be as simple as having your local library proctor the exam. have you tried <A HREF="http://www.mecp.com" TARGET=_blank>www.mecp.com</A> they have a practice exam there.
Re: MECP
Posted: April 8th, 2002, 7:00 pm
by MX-3 Extreme
Well if you dont have any electronics background with resistance and ohm's law and voltage functions ect. then you would never pass even the entry level exam..you need to understand more than just how to hook up a deck or amp before you acn take the test. As for the Ontario Government certification you must have over 4000 proven inshop work hours with remote starters and alarms before they even alow you to take the test. Hope this helps.<P>Killermx3
Re: MECP
Posted: April 8th, 2002, 7:44 pm
thanks alot for the info. i have pretty good knowledge of ohm's law(resistances), voltages and a boat load of other stuff like electrostatics, sound and power thank to my phsyics class :D i'm gonna work the exam online, one thing i remember from it last time i looked(before i took the class) is diodes and i still don't know about them. i'll be donig some research! thanks
Re: MECP
Posted: April 9th, 2002, 1:27 am
by MX-3 Extreme
Well I wish you good luck! It will feel nice to be able to back your knowledge from school with a certificate. As far as I know in the Usa MECP is madatory when becoming a car audio installer. <P>Killermx3
