radio and clock
radio and clock
hey guys. while driving, i turned off my radio and then a little while later, i noticed it won't turn back on and i also noticed that the clock has died out as well. all other electronics are working fine like ac and the turn signals and headlights and etc. anyone know what's goin on?
- team slideways
- team slideways
Re: radio and clock
check your radio fuse in the interior fuse box. If not that.. check the btn in the hood fuse box.. if not that then you've shorted something... good luck
Shaun Newman
Re: radio and clock
i'm not an expert on electronics so...<BR>which one is the fuse box and how can i check if i blew a fuse? it might be that because right now, my whole interior is stripped naked due to interior panels being painted. what about the fuse button in the hood? if i shorted something, can it be fixed?
- team slideways
- team slideways
Re: radio and clock
the fuse box is in the drivers side kickpanel (bottom left). theres a black cover with the names and the amp ratings on each fuse. YOu need to find the radio fuse (bottom right area), pull it out with the puller thats in the cap to the fuse box, and check to see if the fuse is broken (silver bridge in the middle is damaged). If so, replace the fuse with one of the same ampage (color). If not that fuse, check under the hood. To the right of the engine there is a fuse box. Take off the panel and look for the fuse labelled "BTN". These fuses look different from the ones in the car. Pull the BTN fuse and again check for damage. If there's no damage to either fuse that you can see, take it to a shop. its possible you've shorted something out.
Shaun Newman
Re: radio and clock
fixed the problem....thanks a lot man! yea it was the middle bridge that was messed up...it was all torn in half and stuff. i fixed it and got new blaupunkt speakers the same day.
- team slideways
- team slideways
Re: radio and clock
for some reason, my radio fuse keeps blowing out...but i found the problem. if i use a 15 fuse from my power locks to put in the radio clip, will it be ok since i have a 92 rs with no power locks?
- team slideways
- team slideways
Re: radio and clock
um..im not really good in electronics but is the fuse from the power locks the same value as the one in the radio? coz if the value is not the same then i dont recommend you replacing it.
supercharge or turbocharge?
Re: radio and clock
it is the same value...15....so since i don't have power locks...is it safe to swap them?
- team slideways
- team slideways
Re: radio and clock
My radio just died on me. <P>When I removed, the fücker had a penny in it!
............ .......... ........ . . <P>Nick @<BR>NickisGod.com
