Pre-Amp Outputs
Pre-Amp Outputs
does anyone know if I use my pre-amp outputs (on a silly Sony Xplod) for the front or rear that it cuts out the signal from the head to the speakers running off just that?
Re: Pre-Amp Outputs
I don't believe that it cuts out the signal. I run the speakers from the head unit and the subs from the pre-amp outs. have xplod mp3 head.
Wheelz
Re: Pre-Amp Outputs
Quick response is no. They work in unison. By the way? Why not run everything from amps?
1993 MX-3 RS/GS-R Under Construction
