For Sale: Sony XM-1002HX $85+shipping
Car Stereo/Alarm Discussions
Locked
corona
Post by corona »
Description: Sony XM-1002HX Xplod Car Amp 2-Channel 280W Features: <BR>The HX Series give you a choice, high-voltage power rails deliver fender-bending power into 4-ohm speakers and switch to high-current rails for subwoofers and low-impedance combinations, you'll get full power, even into ornery 1-ohm loads. Push your subs 'til they Xplod sony style. Sony's XM-1002HX 100 Watt x 2 Channel amp won't just look smooth in your trunk, it's got the sound to match it. Bridge it to 280 Watts x 1. Also with a 50-200Hz hi/lo pass filter and adjustable bass boost you'll never want to look at another amp again. <BR>Voltage/current mode select 100 w x2 into 4 ohms, 20-20 kHz, at 0.04% THD (hi-voltage) <BR>280 w x1 at 0.1% THD <BR>100 w x2 into 1 ohms, 20-20 kHz, at 0.04% THD (hi-current) <BR>50-200 Hz hi/lo-pass filter <BR>Adj. 40 Hz low freq. EQ <BR>High-level input <BR>High current MOSFET outputs <BR> <P>Condition: , Almost NEW Condition, Tested and Works Great! <P> :)
"Its not how you stand beside your car, is how you race it"<BR> Ja-Rule
corona
Re: For Sale: Sony XM-1002HX $85+shipping
Post by corona »
Andrew_Pakula
Post by Andrew_Pakula »
That's actually the same kind of Amp I had in my car before it was stolen in December. :(
Locked
Return to “Car Stereo/Alarm”
