Bolting in Sub box in Trunk
GMGQ
Is it safe to bolt in my sub box into the trunk? The gas tank is under the rear passenger seats, right? <P>So would it be ok to drill some holes into the LEFT side of the trunk(driver side) for some bolts? Besides the gas tank, is there anything else I need to watch out for? LMK, thanks!<P>------------------<BR>----<BR>Gary Mui ( gary.mui@sinnovations2.com )<BR>Sales Representative<BR>Streamline Innovations 2<BR>Vancouver, BC<BR>604.312.9588<BR><A HREF="http://www.sinnovations2.com" TARGET=_blank>www.sinnovations2.com </A><BR><A HREF="http://mx3slimvisors.2ya.com" TARGET=_blank>mx3slimvisors.2ya.com </A>
Re: Bolting in Sub box in Trunk
Well, I used some 1 inch screws to bolt mine down (it kept sliding around). I did not blow up my car and I have not smelled any gas leaks. I looked under the car and all I saw was the spare tire hump, so I guess the tank is somewhere else (probably under the rear seat).
GMGQ
Which side did you bolt it to? Driver side? How many bolts did you use?<P>Well I have to bolt it down because the insurance company will NOT cover a stolen sub, if it wasn't bolted down to the frame of the car. <P>Thanks.<P> <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by RanMan:<BR><STRONG>Well, I used some 1 inch screws to bolt mine down (it kept sliding around). I did not blow up my car and I have not smelled any gas leaks. I looked under the car and all I saw was the spare tire hump, so I guess the tank is somewhere else (probably under the rear seat).</STRONG><HR></BLOCKQUOTE>
I went to Home Depot and got some small "L" brackets and put one on each side. My box is sitting against the back seat and the subs are facing the rear cargo area. I put one braket on the left side and one on the right side.
