Trunk Amp/Sub layouts
Posted: August 10th, 2001, 1:45 am
by Deano96GS
Hey everyone, i was just curious, i am looking to make a nice setup of my amp and sub / sub box in my trunk, but i need a few suggestions, or even pix of what ppl have done. Any nice custom setups? like amp on the back of the seats, or just a general nice setup to look presentable and clean , when showing it off<BR>thanks Everyone<BR><P>------------------<BR>Deano, 1996 Black GS
Re: Trunk Amp/Sub layouts
Posted: August 10th, 2001, 5:52 pm
by -=deathtrap-mx3=-
i'm making a box with my friend as soon as i get the money. i'll post some pics of my sketches.<P>------------------<BR>93 MX-3
Posted: August 11th, 2001, 1:44 am
by KWK MX3
a nice setup is when you do this:<BR>1-15"(or 2-12"s) in the trunk flat against rear seat. cabinet angle is parallel to seat.<BR>now on top:<BR>make the box height as high as the back seat<BR>so that the original trunk cover will close(security, unless you like having a brick thrown through your nice rear window)<BR>the top you can mount 2-10"s with the amp between them.<BR>I've fit up to a 1200w like this.<BR>the cabinet only needs to be half the length of the trunk.
Posted: August 11th, 2001, 3:48 am
every sub requires a different amount of airspace in the enclosure. build the enclosure to the specific dimensions the company gives you.<P>------------------<BR>93 MX-3
Posted: August 16th, 2001, 6:41 pm
by VizualXTC
I am building a fiberglass enclosure putting 2 12" Rubicon subs facing upward tilted about 10 degrees inward and forward. Then directly in the middle of the trunk, I am puttin my amp under a .5" plexi-glass display with neon light accents.
Posted: August 16th, 2001, 10:58 pm
i want pics, man! have you worked with f/g before?<P>------------------<BR>93 MX-3
Posted: August 19th, 2001, 5:08 pm
by VizualXTC
My dad and I own an auto body shop and we do alot of work with fiberglass. I will post pictures on here when I get the enclosure dome, but it will be a while because I don't have the time or money to do it right now. But rest assured I will have them posted as soon as they are in and painted.....maybe I will take pictures periodically while I am doing it as well.
