help! my computer broke :(
Off-Topic Discussions
curtklze
Post by curtklze »
I down loaded a crappy piece of soft wear and now when I boot up my home computer it goes in to the scan disc mode first then when win 98 comes on I get the illegal operation message and I cant do anything except shut off my computer and try again, but it win 98 never works, I cant even use the start menu it just keeps showing me the error message. HELP!!!!
Yes, I AM a bastard
Re: help! my computer broke :(
one thing you need to try is yo get into safe mode
(if yo dont know how, as soon turn on the computer, keep tapping the f8 key and it will bring up a text based menu, and use the arrow keys to highlight safe mode and press enter to select. If you get a keyboard error, just press f1 to continue and then keep on pressing f8 again., If you never saw the menu and windows starts loading, you've gone to far and will needto reset and try again)
If you can't get into safe mode, your looking at a format and re-install of windows. You could always try re-installing windows overtop of itself,but it rarely fixed problems
<small>[ December 17, 2003, 08:09 AM: Message edited by: Nd4SpdSe ]</small>
Sonicxtacy02
Post by Sonicxtacy02 »
what did you download curt? Depending on the program you may be able to uninstall using a program i have. Do you have a 98 boot disk? If so, run that and see if the problem goes away.
Shaun Newman
Custommx3
Site Administrator
Post by Custommx3 »
Do this...
if its win98...
Boot and press f8 before windows starts.
Select "COMMAND PROMPT ONLY" from the Startup Menu
when @ the prompt type this
SCANREG /RESTORE
It will bringup a menu allowing you to restore your registry from a backed up version. CHECK THE DATES. Select one from the list that was BEFORE you installed this software.
<small>[ December 17, 2003, 09:50 AM: Message edited by: Custommx3 ]</small>
curtklze
Post by curtklze »
Originally posted by Custommx3:
Do this...
if its win98...
SCANREG /RESTORE
will this delete the programs I installed after a certian date? will any thing else be deleted?
I had installed a version of spy killer from download.com I cant remember which version. I got it to get rid of all the spy wear on my computer, my computer has been running really slow from about 3 months, so I tryed to fix it now its dead :( , o well I will try that other stuff,.
Thanks
<small>[ December 17, 2003, 03:15 PM: Message edited by: curtklze ]</small>
Yes, I AM a bastard
monty73741
Post by monty73741 »
first dont every use spy killer
use adware...its the best....
if the reg thing dont work
just reinstall win 98 on top of it should fix the problem
Jason Danaher
Please Help Support MX-3.com
UoMDeacon
Post by UoMDeacon »
Yup, as stated previously, your best bet is to boot into safe-mode and then do some cleaning up and scanning from there.
As for the registry recover, yeah, it'll effectively make it appear to your computer that no new programs after that date had been installed, however, the files will still be on your drive. Only executable files will be affected (I believe), so documents you made after that point should still be fine.
However, to be safe, I would recommend you take the harddrive out of your computer, and plug it in as a slave in a friends computer. This way, you can move all of your documents off of the harddrive onto his, for safe keeping while you try to fix your computer. As may be the case with Win98...you may probably have to reformat the harddrive and re-install Windows :-(
In the future, if you want to get rid of spyware, Ad-Aware is very good, especially when used concurrently with SpyBot Search & Destroy (both are free programs). They will catch everything except for the custom written ones. Good luck with fixing your computer.
<small>[ December 17, 2003, 03:35 PM: Message edited by: UoMDeacon ]</small>
kuruption1983
Post by kuruption1983 »
If you can wait till monday, I could come and return the favours you have done for everyone. :D
I worked for Rogers@home customer service for a while, so i should've learned sometin.
curtklze
Post by curtklze »
thanks for the help, I am in the process of getting a newer computer anyway, I just wanted to get this one working for the next week or two, no big deal of its dead, I will just add this hard drive as a slave to my new computer so I will be able to access my 39 gigs of porn and music :) ) took me 11 months to fill 40 gigs :) , my new one will be at least a P3. :)
Thanks again.
<small>[ December 17, 2003, 06:05 PM: Message edited by: curtklze ]</small>
Yes, I AM a bastard
[quote]Originally posted by curtklze:
I will just add this hard drive as a slave to my new computer so I will be able to access my 39 gigs of porn and music :D :D
UoMDeacon
Post by UoMDeacon »
Nah, with the magic of compression, music should only take up 100MB, leaving the rest to the more important pr0n ;)
phr34k
Post by phr34k »
take win98 toss out window and have someone burn you redhat or slackware linux and yuo = m3n k
Custommx3
Site Administrator
Post by Custommx3 »
use SPYBOT....for spyware.
Its updateable and its free.
Becareful with that SHOPATHOME spyware. I had an issue where when I removed it, I lost internet access. and had to put it back to get back online. A person here @ work was having PC problems and I found tons of spyware.
The scanreg/restore will work just fine as long as you havent applied any windows/IE patches and restore the registry to a time prior to the updates. This works. When I was doing tech support for Dell and Gateway, I used it all the time. I still use it on some PCs when it has issues. IF its fast enough, use XP.
Spydie
Post by Spydie »
I agree with monty. adaware is pretty good.
I also recommend AVG anti virus. I really hate Nortons
monty73741
dood when u get your new computer transfer ur porn & music then..........format It use linux then u have a web server......wohhahhahahahaha
Jason Danaher
Return to “Off-Topic”
