Anyone know if??
Guest
Anyone know if??
i was wondering if the K8 trany will fit on a Millenia S motor and how close the mounts are or are they the same?? i know a Protege that has a Millenia S motor in his car and its 5speed. I am looking to do the swap!
David Coleman
Re: Anyone know if??
Well since the KJ block is a K series, and all other K series have G25M-R trannies, I'd say it would work. <P>However, I do not know if you will be able to run the KJ w/o the ATX imputs since its ECU is very complex due to the Lysholm compressors and the 6-stroke configuration.<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
Guest
well i will run the S ecu too! has anyone doen this swap in an mx-3 yet??
David Coleman
Not that I know of....<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
Guest
there is already a guy with a S motor with a 5speed and i was told its a k8 tranny<P>i know i will have to get a hood made because of clearance problems but i was told thats all i will have to do! anyone got more info on this?
Guest
i think hes in the toronto area i have never seen his car only heard about when i started to ask about this swap! i think his name is Paulo or soemthing like that!
Guest
The S motor has alot of potenial and to get a 2.5 up to its HP rating will prob cost more then the S motor but the S motor could get exspensive if i have to do serious body mods to get it to fit! i know a modified hood will be required but i am hoping thats it
Guest
i will be the hardest part is gonna be finding a decenyt motor with low KM i foudn one in ottawa but it had 150km and thats to much iw ant soemthing with under 100km
Guest
no a guy has it in a Protege not an mx-3 and yes its the miller cycle
