V6 struts on 4cyl ??
Hi. i know the part numbers are different on the V6 struts and the 4 cyl struts. What I want to know is if they will fit. I know the V6 struts are probably a little stiffer than the regular 4 cyl struts, so while changing my struts, I figured I'd go ahead and put the V6 struts, as opposed to upgrading to a very expensive brand.... Let me know what you guys think. Thanks
Re: V6 struts on 4cyl ??
i think the struts are the same,its the springs that are different,they will fit
<small>[ December 05, 2004, 04:19 PM: Message edited by: jimishadow ]</small>
