How Remove o2 sensor?
mx3-precidia-gs-1995
Post by mx3-precidia-gs-1995 »
I got a B6 engine and i need to change the o2 sensor...
How can that be done?
there is not a lot of space .
tx!!
OsoSlo z28
Re: How Remove o2 sensor?
Post by OsoSlo z28 »
go to the auto parts store and buy an O2 sensor socket for your ratchet.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Yoda
Post by Yoda »
Best thing to do is remove the rad fans first which comes out easily. The it is easy to get in there with a O2 sensor socket. Sometimes you will need to heat the sensor near the threads to get it to break loose. I've had cars in and out in under 30 min. I showed this trick to a couple of Montreal area garages who were taking a lot more time than the should to change them.
