intakes for the car
CarMan1
intakes for the car
Post by CarMan1 »
ok, can someone answer this question for me, im guessing that since u have to use the maf sensor off the intake box with a intake u put on, that u cant just buy any intake... could someone tell me intakes they have bought/used so i know what i can use? and also, how did u use the intake and also include the maf sensor in the intake so the car actually runs...
also, im assuming the silver box on top of the intake box that comes stock with the car is the maf sensor... how in the world can u use an intake with this? most cars dont make this a part of the intake so im really confused...
<small>[ October 17, 2004, 09:52 PM: Message edited by: CarMan1 ]</small>
atlantamx3
Re: intakes for the car
Post by atlantamx3 »
I used one for a new Protege5.
You can get them on ebay that are made for the MX-3 though now.
Here is a pic of it on my old 1.6L SOHC:
<img src="http://www.atlantamx3.com/perry/blackvc2.jpg" alt=" - " />
And the same one on my newly swapped BP:
<img src="http://www.atlantamx3.com/BPswap/day4/i ... CT0317.jpg" alt=" - " />
If you dont want a whole intake tube, you can get an adaptor to fit on the stock air-flow meter as I did when I started:
<img src="http://www.atlantamx3.com/perry/vcb41.jpg" alt=" - " />
( I got it from Corksport... Its an HKS model.... but you can get these on Ebay now too for next to nothing, and they come with an air filter.)
Good luck!
~Perry
Please visit
http://www.mx3-atlanta.com
Reprobation14
Post by Reprobation14 »
What about the DOHC models?
I currently have a DOHC model with a stock box and genuine mazda air filter...
I'd like to add some kind of intake system (Preferable CAI). But im not entirely sure how.
I've heard about using a DelSol intake system and modifying it to work for our cars, but again, im unsure about this.
Thanks for any information you can supply!
-Chris
Casino
Post by Casino »
ractive makes one, i used it on my old car it worked ok.
anyway it may say sohc only but it will still work
http://www.realtimeperformance.ca
03 miata, formally bottle fed 96 DOHC
lujacks
Post by lujacks »
I have a DOHC try out this site it is a cold air it works pretty good. http://www.prmracing.com/ check out my cardomain and you will see a pic of the cold air installed.
bolt on cars are pointless you learn nothing and it's just too easy. http://members.cardomain.com/lujacks
