protege or pro lx....
Posted: October 16th, 2004, 12:35 pm
by Domnknpimp
Ok, my tranny is gone, gonna go ahead and swap it out (why wait)... I keep reading that when changing to the BP or BPT, you need a protege lx tranny... is there a difference between a regular protege's tranny and an lx's tranny? I know nothing about protege's so i must ask....
thanks
Re: protege or pro lx....
Posted: October 16th, 2004, 12:43 pm
by atlantamx3
Yep.
The 90-94 Protege LX uses a G-series tranny that is a bit more beefy and I believe has a different gearing ratio.
The regular 90-94 Protege uses an F-series tranny that is also the same one used in the MX-3 RS. (4-cyl).
If you use the LX tranny, you will need the bottom half of the driver side tranny mount as well.
Posted: October 16th, 2004, 2:22 pm
by Domnknpimp
so if I put a tranny of a regular 1.8 sohc Protege, I'm putting on the exact same tranny I have on my car now?
Posted: October 16th, 2004, 5:17 pm
by Gro Harlem
yes
Posted: October 16th, 2004, 6:08 pm
by Joe Carlson
Its going to be the same basic tranny, but i believe that the tranny out of the protege dx has a higher gear ratio. The first bp motor i put in my mx-3 i used the dx tranny, and i could do 73mph in 2nd gear. Now that's higher even that the stock mx-3 tranny, and now i have the lx tranny I can't go much more than 45mph before i need to shift out of 2nd.
Posted: October 16th, 2004, 10:00 pm
by Domnknpimp
damn 73 in second? not bad... i'm guessing its not as strong though?
Posted: October 17th, 2004, 10:52 am
by Joe Carlson
Yeah they're not as strong, and with a higher gear ratio, it makes for a slower take off, but a better top end speed, and better if you plan on putting your mx-3 on the high way alot, b/c now since i have the protege lx tranny, in 5th gear going 75, the motor is at 4,000 RPM's, where as before i was only about 2,800 RPM's which is easier on the motor, and fuel milage. Joe
