Stainless steel clutch line from corksport anyone?!
Posted: October 12th, 2004, 4:22 pm
by alberto95
Has anyone bought the SS clutch line corksport sell for Mx-3? i ordered one, and when i try to install it, it doesnt fit after the hard line that comes after the slave, it too short!.. does anyone knows where it goes? pics? please help!
Alberto
Re: Stainless steel clutch line from corksport anyone?!
Posted: October 13th, 2004, 12:18 am
by mx3TT
I bought one a while back and it fit perfectin place of the rubber line. Its basically right under the battery.
Posted: October 13th, 2004, 12:52 am
by papa roached
i got one, fits like a glove, almost like it was made for it
Posted: October 13th, 2004, 1:48 am
by torpedan
Had no trouble with mine. I will try to get a picture if i dont forget about it.
Posted: October 13th, 2004, 2:18 am
by RoundTop
I have one, what is the easiest way to install it? is there a howto or anything?
Posted: October 13th, 2004, 3:38 pm
by alberto95
Yeah, please post a how to guide or something! thanks!
Posted: October 13th, 2004, 6:37 pm
by RoundTop
Well, in the chiltons manual it says how to redo the entire system, including the line... but it doesn't say how to do it for just the line.
One thing is for sure, you will need some brake fluid and bleed the clutch after you install it.
Posted: October 13th, 2004, 11:13 pm
by mx3TT
Its simple. Get the fluid out of the lines. Disconnect the soft line by popping those little clips off and screwing them off the hard lines. Mine were rusted to the hard lines so it was a little tough to get off. Once you get the line one, put the clips back on and fill lines and bleed clutch.
Posted: March 25th, 2005, 1:25 pm
by Macen
Got one too. Fits like a glove. Easy to install. Remove battery and air intake. Then just loosen the two bolts. Remove the old brake line, and insert the new one. Took me half an hour, and I'm no mechanic.
gravy
Posted: March 27th, 2005, 6:51 pm
by forcedairram
I just installed one on mine, went on like a glove, 30 minutes including the bleeding.
