How to jack up car to add more tranny oil than normal?
jumboplay
Post by jumboplay »
This weekend I wanted to add extra tranny oil because it might be a bit low. What side or part of the car would you lift up to allow more fluid than the regular "full" line? I've read it on here somewhere, so surely someone knows from experience...
Thanks guys.
-Tom J, proud MX-3 pilot-
Get your entertainment upgraded at http://www.tommyv2.com
1996 MX-3 RS/GS hybrid, OBDII B6-ZE, painted Mazda crystal white, ZX-2+Eibach, Miglia Spyder 17"s, markerflash, black altezzas, insane fuel economy, too many other mods to list...
Custommx3
Site Administrator
Re: How to jack up car to add more tranny oil than normal?
Post by Custommx3 »
Auto or 5 speed....
jumboplay
Post by jumboplay »
5 speed, oops forgot to mention that.
OsoSlo z28
Post by OsoSlo z28 »
if it's to the fill line, it's not low. there is no need for more fluid hence the purpose of the fill line.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Post by wytbishop »
The fill line is very important to the life of your tranny. More than the recommended level of fluid will increase the pressure in the tranny and eventually blow out the seals. And having more than teh recommended fluid level will not give any advantage at all.
rayrrod
Post by rayrrod »
Tommy, does not make sense..you say>>>>
??? so its low?
but then u say>>>>
now u want more than full?
those 2 statements do not agree.
jumboplay
Post by jumboplay »
I changed my fluid a couple years back. I think perhaps I didn't put enough...I just used the capacity specs and didn't really use the line. I figure a little more can't hurt, especially it's been low all this time...
Post by Josh »
a little low is way better than a little over full. and you should fill it when the car is level, not one end higher than the other.
