Fuel Injectors??
Posted: August 26th, 2004, 11:34 pm
by manowar821
I was looking at the products on.
http://www.racingmazda.com/
They have for the mazda MX-3 two types of Fuel Injectors available, Peak & Hold Injectors and Saturated Injectors.
What is the difference?
Re: Fuel Injectors??
Posted: August 27th, 2004, 2:35 am
by OsoSlo z28
saturated is high impedance (resistance), and p/h injectors are low impedance. MOST cars use saturated injectors, while a few turbo model cars use p/h. basicly, whatever type your car is setup for is what you should use. this can be determined by taking a resistance reading of the injector. generally, a saturated injector is about 12-16ohms.
Posted: August 27th, 2004, 2:55 pm
by Ma-Ze
Originally posted by manowar821:
I was looking at the products on. http://www.racingmazda.com/
You will need a stand alone unit to use peak and hold on an mx-3
Posted: August 29th, 2004, 2:01 am
by manowar821
How exactly would I go about getting one for a sohc 92 mx-3??
Posted: August 29th, 2004, 11:38 pm
by Ma-Ze
why would you even want bigger injectors? i dont know what kind mods you have but your sig only says a custom intake. injectors alone wont give you any increase in performance. im using a tecIII unit which cost $2500 for a bare unit. you can order one from racing mazda.
Posted: August 30th, 2004, 8:24 am
by OsoSlo z28
agreed, unless you're getting a highly increased amount of air into the engine, as well as out, you have no need for bigger injectors, of either type. extensive internal work and/or a turbo or s/c setup would warrant a bigger injector. I was using a Haltech E6K, now E6X, and was a good option over the higher priced TEC setups.
