Mx-3 Mx-5 interchange
Posted: July 20th, 2004, 10:53 am
by projectmx
I was trying to do some reaserch on the clutch and flywheels from them miata and seeing about putting it in the mx-3 since my clutch is beginning to slip and i got a bit lost i think i know less about trying to get a better clutch and flywheel for the mx-3 than before searching. so i have a few ?s.
1. can a miata flywheel be put in the mx-3 dohc transmission.
2. can a miata clutch be put in the mx-3 trans
3. asside from cams/ cam gears can other internals go from the mx-5 to the mx-3 like crank / pistons / ect.?
if we ever get some diffinitive answers to these ?'s we should put them in the 4 cycle FAQ section.
Re: Mx-3 Mx-5 interchange
Posted: July 20th, 2004, 5:00 pm
by violent_J_54021
1. A Miata flywheel can be used in the MX-3 DOHC, I have one in my car right now
2. A miata clutch can not be used in the MX-3 DOHC tranny. The splines on the shaft in the transmission is different. You can use the pressure plate off of a miata, but it's eaiser to just buy a mx-3 clutch kit.
3. Most internals from the Miata will work in the MX-3. There are a few diff. though. I would not recommend trying to put a miata head on the mx, it's just too much work. Also, the water pump is different, and the oil pan and oil pickup is different. I believe everything else will work.
Hope this helps,
EricT
Posted: July 21st, 2004, 10:11 am
by projectmx
head i wasn't going to try after asking around about that but i thought maybe pistons and crank to strengthen the bottom end just a little. then of course the cams and cam gears. so any flywheel for the early 90's 1.6L miata will fit just fine with the dohc and mx3 clutch kit?
Posted: July 23rd, 2004, 10:35 am
by violent_J_54021
yep, any flywheel from the 1.6 miata will work. That is whats in my car now, A miata flywheel with an MX-3 ACT clutch.
