Header for 1.6L?
Header for 1.6L?
Is there such a thing? is it available here in the lower mainland? or do I have to get one custom built? all info is greatly apprieciated, but not in a hurry to add it just yet.
- dj inferno
Re: Header for 1.6L?
i don't think so unless ur running a DOHC, in which i BELIEVE... im not positive, but i think u can use ford probe headers... but i think your gonna need to go w/ a custom job ![Smile :)](./images/smilies/icon_smile.gif)
- violent_J_54021
they never made headers for the SOHC, but if you do have the DOHC you can use the headers for a probe 2.0. You just need to drill your own holes and take some metal out of the middle two runners. If you do a search there is a step by step process for it.
94 DOHC
Miata B6-ZE engine
ACT 4 puck clutch
workin on the money for a turbo...
Miata B6-ZE engine
ACT 4 puck clutch
Marcor-GEnie does make a header for the sohc it is supposed to be in stock by mid july that is what they told me when i called for the hundredth time now it says 384cdn for them on there website: marcor-genie.com
