cold air intake
cold air intake
hey i was looking at the sohc intake on ebay and it seems to me like it would fit...but i dont know what the gain would be since we dohc guys have a long intake mani can anyone help i want to kno if i get a long intake tube what the gain will be and if i need to upgrade the fuel system or what i need....torpedan help!!!!!!!
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
- monty73741
Re: cold air intake
it should fit.....the intakes are the same for the sohc & dohc
Jason Danaher
Please Help Support MX-3.com
Re: cold air intake
yes it fits...try ther one by XOXOPART....
really good service !
Re: cold air intake
You can make a lot of diffrent things work. The performance gain on a DOHC though is minimal. The largest restirction in the intake stream is the MAF. Its a firewire style and can flow good volumn. But it is still tiny.Originally posted by schwankesmx3:
Here are a few pictures of things i have crafted in the past. Thewe usually reuse plastic intake peice after the maf for a bunch of diffrent reasons but they are prone to crack easily and that will warrent there replacement.
This is a picture of a PVC intake. Its ghetto, but sweet jesus its cheap and the bends in it are smooth. Best part is the use of the duct tape. The intake actually pulls air from what used to be the vent for the battery. If you follow its snorkle down you find a nice cubby hole for a fitler and you can see what we enlarged to pull non engine bay air.
The 2nd picture is just a short ram we had to use for a bit before the pvc intake. This picture really shows the posistion of our relocated Overflow resivour. It fits snug and nice there but if you have cruise control its not a option.
<small>[ June 21, 2004, 05:41 PM: Message edited by: torpedan ]</small>
-torp.
I don't own a Mazda.
Re: cold air intake
but should i upgrade the fuel system???to like a 21LBS an hour injector?? i was told that i might want to upgrade the fuel flow to compensate for the more airflow ...is this true....another question again will i get more power out of a long tube intake vs. a short tube intake
Re: cold air intake
The stock fuel system should be able to handle it. For the most part stock systems run on the richer side of the line to begin with and can affoard more airflow.
-torp.
- Casino
Re: cold air intake
it doesnt do to much but every little bits helps
Re: cold air intake
Umm it really wouldnt do anything but make the car run rich.. =]Originally posted by Casino:
-torp.
Re: cold air intake
so then Torpedan what would you do ? what mods have you done ?
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
Re: cold air intake
Excluding the pictures iposted of my car.Originally posted by m92_MX3:
1. torpedan 15.558 @ 88.9 MPH - BPD, Gutted(2290lbs w/driver), Indigo Flywheel, UDP, 1 7/8 exhaust, Nology Wires
That is outdated. The car runs in the lower 15's i have yet to take it to a 1/4mile track though. There are servral unlisted additional mods..
-torp.
Re: cold air intake
Is there a larger MAF that can be used in order to increase air flow? Hopefully a swap that can be done?
This would be on a 94 1.6 i4, BTW.
Re: cold air intake
Honestly i am not sure. Your best bet would be to find voltage paramaters for other airflow meteres and compair them. You would be surpired how mnay more will swap than people know about. I have come across documents as such on occasion. Its very apalling. I wish i would have jotted some of them down given my memory sucks.Originally posted by Spotted:
As stated do the research first, just pluggin in a diffrent Maf could fry something.
-torp.
Re: cold air intake
I just want the answer, I don't want to research anything...
Just kidding. What voltages would I have to research? I am willing to research and post my findings here.
Just let me know what to look for.
Thanks
Thanks
Re: cold air intake
hehehe. A MAf is actually a Set of ssensors. Each one has a particular voltage that is its output range. You find out what the stock one is then find other sensors that operate in the same range.Originally posted by Spotted:
Thanks
-torp.
