electrical questions
Zeak
Post by Zeak »
ok i was turning a corning the other day and it seemed like someone unpluged all my plug wires pulled over no spark. i get the tow truck and bring it home with in hand 2 used distributers spark timer and coils computer and every relay in and on the car. still no spark. i use hollander interchange and it says the multifunctioner is on the left side of dash. i cant find it. is it with the fuse box or what? someone please help me i need my car running..
or does that spark even go through the multi?
1993 mx-3
please help me.!!!!! :crying:
torpedan
Re: electrical questions
Post by torpedan »
THat is a very odd thing to happen. It took me a bit to figure out what you were refering to and what you have done.
I presume you have replaced and checked your cap rotor and wires. Although this is not the place i would look. You mentioned it was a 93 so i presume you have a SOHC motor. Correct me if this is wrong.
Assumign there are no problems with the coil and the assocated connections it makes i would also check to be sure the Mass airflow sensor is propely plugged in. I would check the prongs for corrosion as well.
I would also check all the fuses. Including the ones in the engine bay. There in a lil black box located on the drivers side.
-torp.
I don't own a Mazda.
