lost spark!!!!
Mel P. D.
lost spark!!!!
Post by Mel P. D. »
Today as i was driving it seemed liked it stalled as i down shifted. I changed the spark plugs, cap and rotor under the cap, also got a couple used coil packs but still no fire. COulld any one give me some advice to what else i can do or check before i say screw it and take it to a real professonal. need answer like ...yesterday!! Thanks..
Joey's mx
Re: lost spark!!!!
Post by Joey's mx »
Sounds to me like it would be the distributor...Im not 100% possitive but a couple of guys here had the same problem and it was that!!!! Your talking big money there!! Good luck
Joey's mx
Re: lost spark!!!!
Post by Joey's mx »
Its sounds like the distributor!!! A couple of guys had that problem here and it was that..not 100% possitive but sounds like it and would get it checked!! Your looking at big$$$ there!! Good luck!!
OsoSlo z28
Re: lost spark!!!!
Post by OsoSlo z28 »
have you checked for spark for each cylinder? what year is your car?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Mel P. D.
Re: lost spark!!!!
Post by Mel P. D. »
its a 92 changed the pluggs. well i have to check the disributer then.. i let ya'll know what it is.. :crying:
OsoSlo z28
Re: lost spark!!!!
to check to see if you have spark, unplug your fuel injectors, pull the plugs out (leave them in the plug wires) and lay them across the valve cover. have someone watch them as you start the car. check to see if any of them have spark. this will help you narrow your search.
"MR." Ashley Fowler
cardomain pics
