can someone please tell me where resistor mod chip is actually put diagram if possible
i have mazda mx3 1.8i v6 1995
much appreciated juliesitruc@aol.com
modchip
Re: modchip
In the garbage!
I evin heard of one of those pieces of crap they sell on ebay causing engines to blow up.
Eugene L
1.6DOHC
http://www.cardomain.com/memberpage/552384
Eugene L
1.6DOHC
- papa roached
Re: modchip
preach on brother
Re: modchip
This is a possiblity but if suffient octane is run it shouldnt be a problem. They work by making the comptuer think the incoming air charge is of a diffrent temprature and cause it to advance the timing.Originally posted by Ehpl:
In the garbage!
Eugene L
1.6DOHC
Its not worth buying soemthing off ebay given yuou can get it at radio shack for 20 cents.
Unless you really know what you are doing though iw ould suggest you dont do it.
-torp.
I don't own a Mazda.
- Casino
Re: modchip
dont buy it it will do nothing but hurt your car, tricking the computer into thinking you have colder a ir then u really do well just cause your mixture to become richer then it needs to be
