This is my problem: Engine is overheating consistently.
This is what i did so far:
- removed thermostat
- flushed radiator, hoses, engine circuit with a water hose
- refilled radiator and overflow tank w/ coolant
- made sure waterpump was working
- fan is working
More details:
The engine was overheating long time ago, so I changed the thermostat and it was running fine.
Not so long ago the waterpump belt broke and I replaced it. Water pump works (water was gushing out of hose when i disconnected the radiator hose and accelerated engine)
Waterpump has been replaced 6 months ago.
I don't know what else to check. The car does not overheat that fast when heater is on, but it still overheats if I drive with 65mph for more than 20-30 minutes.
I've been reading the posts on this forum and people mentioned head gaskets. I need someone to tell me how to check for head gaskets problems. The more detail, the better
Right now I'm driving with the heater on all the time and it's quite uncomfortable.
