using a B6-T ecu in a 92 RS HELP!!!!
Howdy........has anyone tryed to piggy back a capri xr2 ecu (B6-T) into a 92 RS. I have a 92 rs with a B6-T motor in it and I want more power so i decided to try and wire in the B6-T ecu, any help would be great, so far I have weeded out all the extra stuff from the B6-T harness (every wire the motor deosn't need) and i have that already to go into the mx, I just need some help figurung out were and what parts I need to swap over to make it run and the guages to work. thanks again
- Shady469
Re: using a B6-T ecu in a 92 RS HELP!!!!
your wasting your time. put in a Pro LX ecu or your SOHC ecu for that matter and use a piggy back(as in APEXi S-AFC) on it. using the b6t ecu wont help: it has the ackward vac advance disty, boost/fuel cuts built in: everything you DONT want(if you plan on doing anything more than stock set-up).
<small>[ May 08, 2004, 05:07 PM: Message edited by: Shady469 ]</small>
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
