cheap and easy power!!!
hey guys just thought id let you know that if you put a 60mm throtle body on the b2ze you WILL gain at least 9hp!!!!!! i got mine from a escort GT and you can put a delsol intake on the dohc with no mods needed thats about 3-6hp gain ive done both of these and i have no problem with racing hondas at the track........
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
- papa roached
Re: cheap and easy power!!!
a honda del slow intake?
Do you mean B6ZE? I've never heard of a B2
![Werd :werd:](./images/smilies/werd.gif)
Later, D
92 4-banger (totaled unfortunately. Current ride is 2001 Mustang GT)
yes a honda del sol intake ....my-b i ment to put b6ze
People have been hacking up intakes for a while now.Originally posted by schwankesmx3:
There is a FAQ with the throttle body swaps listed somewhere
-torp.
I don't own a Mazda.
- violent_J_54021
what kind of DelSol intake? what years and models?
94 DOHC
Miata B6-ZE engine
ACT 4 puck clutch
workin on the money for a turbo...
Miata B6-ZE engine
ACT 4 puck clutch
http://www.teamdelsol.com/technical/howto/coldAirIntake/default.asp
This isnt what your looking for. But it gives you the basic idea of how to make your own intake.
-torp.
what year escort? we need more info!Originally posted by schwankesmx3:
Let the boost be with you!
- MX3-Freak
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
- Limegreen mx-3
i have the sohc and i tried that a while back got a 1.8 dohc trottle from a protege and turned out the sencers are different. mines had a bar sticking out and the pro. trottle had like a clip sencer. any infoOriginally posted by MX3-Freak:
READ THE FAQ"S!!!!
