I HAVE NO EGR VALVE????
Ever since i bought this car all the idle problems i have had with it everybody said: check the EGR valve.... so i went to check it today and could not find it so i looked in my chiltons and there was nothing about the 1.6L so i got on here and looked and found some very good replies about the location.. so i went to look for it and it was not there... to make a long story short i ended up taking off the whole intake manifold and throttle body looking for it... and never found it... but thats ok cause i needed to clean them out anyway... but i don't know what to do now... i mean how good can that be not have a EGR valve? is this common? thanks
Zoom-Zoom
Re: I HAVE NO EGR VALVE????
Its fine not to have an egr valve!!! Its only has to do with emissions.....recycles exhaust back into the system!! If you would swap to a engine from Japan it also wouldnt have an egr valve. I wouldnt worry about it, its not hurting anything!!
