![Welder :welder:](./images/smilies/welder.gif)
b6t question
b6t question
do i have to run an intercoller with mt b6t swap, i can get the intercoooler but can't run the piping cuz my bodykit is molded on. is it possible to cool the turbo any other way. ![Welder :welder:](./images/smilies/welder.gif)
![Image](http://images.cardomain.com/member_images/7/web/379000-379999/379944_3.jpg)
- papa roached
Re: b6t question
i hear liqud to air intercoolers work decent
