1993 SOHC --> 1995 DOHC
Cryogen-X
Post by Cryogen-X »
How hard will this swap be?
i can get a 1995 DOHC for 200 bux with a blown tranny.. also can i use the tranny from my RS SOHC for the DOHC motor and what else would i need they r both 4cyl.. so i am thinking if ai can get this DOHC i can pull it junk the old body and Rebuild it then drop it in my RS and have more power... :)
any help would be grrrreat :)
I love my Car!!
papa roached
Re: 1993 SOHC --> 1995 DOHC
Post by papa roached »
should be a swap and drop from what i have read, just swap the engine, ECU, anything else i aint sure of
OsoSlo z28
Post by OsoSlo z28 »
and the COMPLETE wiring harness
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Seanthepizzadude65065
Post by Seanthepizzadude65065 »
would someone please explain all that you have to do in this swap?
14" 5 spoke PRIME rims, GS spoiler,180 Watt Sony Head unit with a 4 Polk Audio EX series speakers, Kicker Solo Baric 8" sub, StrandTec custom Air system, Blue under dash neon tube, Blue windsheld wipernozzle LEDS,straght-through dual tip exhaust, Belive it or not but, I did a 0-60 in 7.23 seconds!
http://www.cardomain.com/id/seanthemx3er
papa roached
pull old motor, install new motor, pull old wire harness, install new one, install ecu and hook everything up
65stang
Post by 65stang »
I would unhook the harness and pull the harness with the motor. It is much easier that way in my oppinon
Cryogen-X
Post by Cryogen-X »
wil my SOHC tranny work on the DOHC
I love my Car!!
