Horn stopped working. Any ideas?
Posted: January 10th, 2004, 10:45 pm
by jumboplay
Recently my horn stopped working. All fuses and relays checked, I hear it click when I try it, nothing happens. Any common problems with this? Also, where is the horn itself, since the online shop manual seems to have disappeared? :-\ . Any help would be appreciated? Or maybe I'm just low on horn fluid? Hehehe...
Re: Horn stopped working. Any ideas?
Posted: January 11th, 2004, 6:59 pm
by UnkleDuke
The horn is usually up around a headlight, but I'll check my manual when I have a chance.
Posted: January 14th, 2004, 9:55 am
by Kenzie
Mine suddenly stopped one day when I was using it to let someone know exactly how much I appriciated them cutting me off and then about a week later it started working again. That's the only time it's happened and I've had my car about 3 years.
Posted: January 14th, 2004, 2:08 pm
by Freq2002
If I remeber right, the horn on my car was in front under the bumper cover, passenger side I think. You should be able to see it if you can get your mellon under the front & look up.
Posted: January 21st, 2004, 8:31 pm
by 992mmx3
You sure you checked the wire to see if it wasn't getting squashed somewhere in the steering wheel area. This happened to my friends car.
Posted: January 31st, 2004, 6:04 pm
by brody125
mine is doing the same thing
Posted: February 2nd, 2004, 6:59 pm
by dj inferno
a few days after i bought my car i tryed out my horn (its a week ***** horn lol) and it worked a few times, but i was drivin by my friends house and i honked and it didn;t work.... so i tryed it sum more, and it didn't work for like a week, then i tryed it like a month later and it worked fine, havn't had a prob sence.
Posted: February 3rd, 2004, 11:34 am
by Gabby
I have had this problem happen to another car of mine. The problem was the wire had some how managed to come loose from its holding. Just try to find the wire and re-connect it. It's not something a that is going to take forever or is hard to do. On the Flip side if you think your horn is to meek then now would be the best time to get a new one.
