SOHC to DOHC
- SE-Man
SOHC to DOHC
What all do I need to change my 1.6SOHC to a 1.6DOHC? Besides just the engine.
- monty73741
Re: SOHC to DOHC
u probally gonna need an ecu & harness.....
i think it would be easier to do a bpt swap
Jason Danaher
Please Help Support MX-3.com
Re: SOHC to DOHC
it's a PITA and not worth it. swap in either a b6t or bpt. a little bit more money, but definitetly worth it IMO.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- papa roached
Re: SOHC to DOHC
if you want a real easy swap, put a 1.8 DOHC BP from a Protege
Re: SOHC to DOHC
is there any kind of swap that you just drop the motor in and hook it up? just wondering
- monty73741
Re: SOHC to DOHC
the sohc engine.......
u might find one on www.car-parts.com & then buy a turbo kit.........from racingmazda.com
Jason Danaher
Re: SOHC to DOHC
the bp swapOriginally posted by flamming skull:
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: SOHC to DOHC
where i could i get the engine at?
