ticking lifters!?
The_Great_Tonge
ticking lifters!?
Post by The_Great_Tonge »
alright so..they tick!!! but they dont do it all the itme, the 2 times t does it is when i need an oil change, and the when i 1st turn on the car. after a little bit of driving the ticking stops. :bowdown: so i dont know whats casuing it, any ideaS?
Marlon
Re: ticking lifters!?
Post by Marlon »
get an engine flush and some new oil and that should take care of it(hopefully)
it;s the hla's with not enough oil
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
gsrbomb
Post by gsrbomb »
Put 500ml of AUTOMATIC TRANNY FLUID in your engine oil. The passages for the oil are small and carbon deposits close them a little bit when you have old oil/many miles engine.
Any grade of AUTO fluid is good.
You can run with them in the oil. Drop your oil next oil change.
The auto tranny fluid has many detergents and decrease the deposits very well.
-1994 GS ENTIRELY STOCK, BUT NOT FOR LONG!-
mitmaks
Post by mitmaks »
ive read on hotrod website NOT to use engine flush (i used it every oil change) since that stuff makes it even worse on your valvetrain/ticking. and ive read that auto tranny fluid does help. ive gotta try myself.
Krist B.
Post by Krist B. »
so it means we can mix the auto tranny fluid with the our engine oil, right?
Marlon
Post by Marlon »
why whats wrong with it?
why do u use it every oil change?
2004 RX-8 - Project
mitmaks
Post by mitmaks »
how many qts of auto fluid do i put in? like 3qts of regular oil and 1qt of auto fluid?
