intake for sohc question
sweetmx3
Post by sweetmx3 »
when u take all the stock air box and everything else do u need to use that box with the hose sticking out of it behind and below the headlight. do u need to do any hting with it
Joey's mx
Re: intake for sohc question
Post by Joey's mx »
if you are running a cone type intake take all the factory air box and piping out, you will not be using any of it!!
