R there any 5spd. transaxles out there for my mx-3
mxtreme38
Post by mxtreme38 »
I've been looking for a 5spd. trans. upgrade for my 92 4cyl.sohc. Does anyone know where they are? :shrug:
Rockstar
papa roached
Re: R there any 5spd. transaxles out there for my mx-3
Post by papa roached »
the protege tranny would work, but you need the half shafts, clutch and flywhell from a protege too
TsiMiata
Post by TsiMiata »
www.car-part.com<p>That should turn up a few dozen for you.
91 Eagle Talon Tsi AWD *RIP*
mxtreme38
Post by mxtreme38 »
Thanks a lot for the info. See ya on the road soon. :D
Rockstar
