hey
hey
Whats up ppl.... Went to J.K. Auto Parts & Finally got my transmission.. now... the guy there gave me a 1.8 J-spec Tranny.... The bell housing looks the same... thing is i havent checked to see if it would fit... i drive a 1994 1.6 RS and the Tranny Came From a 1994 J-SPEC BP 1.8L Let Me Know If I'll Be Alrite... Ciao
BP POWERED MX-3
http://members.cardomain.com/bbprecidia
Re: hey
tranny mounts? are u sure i need tranny mounts? cuz this transmission looks to fit... but i havent checked.... if anyone knows about this please respond thanks...<p>[ May 02, 2003: Message edited by: ALLSPEED GiNO ]</p>
BP POWERED MX-3
Re: hey
GREAT JUST GOT SCREWED! Attemped To Install it This Morning...... and the throttle pin had 22 spleens where as my clutch had 20.... so i guess no j-spec tranny for me....
im not gonna buy a freakin new clutch! all i want is my stock tranny... or anything with the same bolt pattern and same amount of spleens on the throttle pin.... anyone have any ideas?
BP POWERED MX-3
Re: hey
you do have a clutch kit for a protege right?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: hey
no why i need one? how much is that gonna cost? isnt it just better to get a stock tranny again?
Or Will i notice better performance with the 1.8 j-spec tranny? Also is the protege the only car i can get it off of?<p>[ May 03, 2003: Message edited by: ALLSPEED GiNO ]</p>
BP POWERED MX-3
Re: hey
Why are you using a G25 tranny with a B6? The only time you should be using that tranny (in most cases) is with a BP swap. You will need the mount as well as the different clutch in order for this setup to work on you B6. May even need to swap axles (could be wrong).
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
Re: hey
CRAP! lol so i wont get any better performance? and how much do you think a clutch would cost...? also what are swap axles? :S teeheh thanks man.
BP POWERED MX-3
Re: hey
Sure a stock tranny would be simpler to put in but what if that "j-spec" tranny has an lsd? Wouldn't you want to keep it? I sure would. Find out if it has the lsd first. If it does, I would upgrade the flywheel and clutch. Doing so would be a good performance increase - better grip, better handling, better cornering, greater clutch capacity. If it doesn't, well, what you do with it is up to you. Essentially what you are doing is the tranny portion of the BP swap, refer to the FAQs for notes on that. I can't guarantee that you would need the axles but to the best of my knowledge I think you will.
Chris Malden
MX-3 RSR
MX-3 RSR
Re: hey
Okie... Thanks a Bunch Chris! I'll Let you guys kno What Happens By Tuesday<p>Thanks To Everyone Else! You Guys Are The Best!<p>[ May 03, 2003: Message edited by: ALLSPEED GiNO ]</p>
BP POWERED MX-3
Re: hey
Chris Malden
MX-3 RSR
MX-3 RSR
Re: hey
Wut clutch can i drop in that will fit this tranny? can some one give me a list of clutches??? Prices too.... CDN$ thanks.... Ciao.<p>[ May 04, 2003: Message edited by: ALLSPEED GiNO ]</p>
BP POWERED MX-3
Re: hey
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Ryencool:
wow....do research before you spend money, jsut works out better that way...<hr></blockquote><p>don't mean to sound like an @$$, but he's right. make sure that what parts you have will do the trick before you start any project.<p>[ May 04, 2003: Message edited by: cre8v mx3 ]</p>
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
