How do i install sleeve kit over hoses
Posted: July 28th, 2002, 8:22 pm
by roly_39
I'm sure i can't just take all the rubber hoses off. I know i just have to remove one side, but which hoses can i remove with no problem, and which ones do i need precaution with? Thanks for any help....I've had this sleeve kit for months and never had the time/patience to put it on...<P>Rene
Re: How do i install sleeve kit over hoses
Posted: August 7th, 2002, 1:28 am
by flicker454
if you are doing vaccuum hoses, they will be the easiest, and you can remove them without worrying about leaking any liquids. be careful with the hoses coming out of the rad, especially if the car is hot. if you have to take them off, drain the antifreeze out of your rad and then take them off.
