Page 1 of 2
Is this a good deal for a Catback?
Posted: December 4th, 2002, 8:06 pm
by azmtbkr81
I've been shopping around for a good deal on a catback exhaust and here is the best I have seen:<P>MagnaFlow stainless steel 6in diameter muffler w/ my choice of tip design<P>2.25in piping from the cat back. <P>grand total: $310<P>Is this comprable to what you guys have paid or seen?<P>Thanks
Re: Is this a good deal for a Catback?
Posted: December 4th, 2002, 10:49 pm
by xXx_OTEP_xXx
SIX INCH TIP...<BR>is that even possible?<P>do <B>not</B> get a 6 inch tip, my 4 inch tip is too big... 2.25" piping is what you need tho, and 130 isnt bad..
Posted: December 4th, 2002, 10:53 pm
by dropitlikeitshot
i got my cat-back done for 90 bucks and i got the muffler for 150. total was about 240. Check my site out to see how it came out!
Posted: December 4th, 2002, 11:05 pm
by azmtbkr81
The diameter of the can part of the muffler is 6in, the tip is only like 2in diameter. 6 in tip, damn-that would be way ricey! :p
Posted: December 5th, 2002, 5:03 am
by 992mmx3
Thats not a bad deal.
Posted: April 20th, 2003, 3:29 am
by 93' blackmx3
Go to nopi.com they have a full catback with muffler for like $170
Posted: April 20th, 2003, 3:32 am
by jamario
Go to J.C. whitney.com they got catbacks for $159 that's including shipping.
Posted: April 20th, 2003, 2:07 pm
by Marlon
and they rust out in 6 months
Posted: April 20th, 2003, 5:11 pm
by Len-Dogg
I have the Pacesetter exhaust that you guys are talking about and I have had it for about 8 months now and no problems at all. No rust or anything. It's not a loud system though, so if you are looking to get a race car sound out of your exhaust this is not the one.
Posted: April 20th, 2003, 8:04 pm
by Sonicxtacy02
i've had my pacesetter for over 2 years with no probs. This guy is in Arizona, there wont be much of a problem with rust
Posted: April 20th, 2003, 9:53 pm
by Timmyd865
Does that monza system here..
http://www.jcwhitney.com/productnoitem.jhtml?CATID=34088&BQ=jcw2&_requestid=63632 does that work for the 4 cylinder? Notice it says years 92-93... hmm... Anyone have one on a 94-95? This is a good price! Anyone know if it also comes with a high flow cat or anything?
Posted: April 20th, 2003, 10:33 pm
by Len-Dogg
Good question, and I wish I would have asked that before I put mine on. Will it work? Yes and no. What I mean is that yes it will work, because I made it work on mine. But it's not a straight bolt on like it should be. For some reason Mazda decided to change the orientation of the joint that you would bolt this thing onto in 94. So that is why there is a year limitation. To get past this you could have the people that are putting it on for you cut off the flange and turn it, and then re-weld it. Or, you could do like I did, and just pull the stock half of the exhaust to the side some until it lines up and then bolt it. The problem with that is that the joint now touches the bottom of the car! I put a big leather pad in between the bottom of the car and the joint so that it's not metal on metal contact, and that fixes it 80% of the way. Sometimes you can still hear it though at certain resonate frequencies of the car. So there you go. Why Mazda decided to change that is beyond me, seems pretty stupid. Oh well. For the price (which is less than half of the competing systems) it seems pretty good.
Posted: April 21st, 2003, 12:49 pm
by torpedan
Why is a easy question to answer.. 94 was when the 4cyl got a DOHC motor from the SOHC. Diffrent motor.. diffrent design.. simple enough.<p>and personally i would got with a 2in exsaust 2.25 is to big.
Posted: April 21st, 2003, 1:00 pm
by Len-Dogg
Sure the motor is a different design, but they could have kept the interface at the catalytic converter the same. That is just a piece of flat metal with two screw holes in it, it doesn't depend on what kind of engine you have. Seems to me that Mazda wasn't thinking about people replacing the exhaust. Oh well.
Posted: April 21st, 2003, 9:00 pm
by azmtbkr81
Thanks for the help guys but this is a way old topic, I got my catback put on like 6 months ago. I ended up going with the Magnaflow and 2 inch catback piping and it costed me $275.
