Miata 1.6 L Parts?
maniacle_mx3
Miata 1.6 L Parts?
Are they interchangeable wityh the 4 cylinder DOHC in my 1995 mx-3. I don't care if I have to make hood mods to make it fit
1995 Project MX-3 RS<BR>Many mods to come......<BR><A HREF="http://geocities.com/maniacle_mx3" TARGET=_blank>My Geocities Site</A>Updated July 9, 2002. <BR>My site has been newly redesigned<BR>Sounddomain:<A HREF="http://www.sounddomain.com/id/maniacle_mx3" TARGET=_blank>PeeWee MX-3</A><BR>Both sites updated
- monty73741
Re: Miata 1.6 L Parts?
none are interchangable<BR>jason
Jason Danaher
Please Help Support MX-3.com
- Shady469
mmmm i think some are (cam gears...). there was some talk about the cam shafts themselves fitting but something about they are reversed (i.e. intake for exhaust). might wanna talk to boosted, maldo, or cjthor.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
maldo
None of them fit?? News to me.<P>The cams work, just need to be switched ex/in. Cam gears work. Entire short block works just fine. Clutch and flywheel work if you have the BP tranny. Valvetrain works. The solid lifters off the '99 NB head will work on the B6 head. <P>About the only thing that doesn't work is the bare head and manifolds.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
boostedmx
everything in my engine is from a miata,<BR>carillo rods<BR>wiseco pistons<BR>copper headgasket<BR>all engine seals<BR>arp main studs <BR>arp head studs<BR> and the rumor of having to switch the cams is definatly wrong too. the miata 1.6 has an exhaust driven sensor and the dohc mx3 1.6 distributor is exhaust driven too.
maldo
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>and the rumor of having to switch the cams is definatly wrong too. the miata 1.6 has an exhaust driven sensor and the dohc mx3 1.6 distributor is exhaust driven too. <HR></BLOCKQUOTE><P>That should have "clicked" when you mentioned that about the valvecover I offered you. You only have to switch cams on the B6T head. If you look at a miata head, the CAS is on the right side of the rear of the head (exhaust cam). Rotate 90* and you have the B6ZE in the MX-3.
Chris Malden
MX-3 RSR
MX-3 RSR
- monty73741
fellas that was my mistake......<BR>i thought he meant the whole engine....not the parts....<BR>jason
Jason Danaher
maldo
Whole engine can go in as well. Motor mounts need to be changed and the coolant inlet on the head has to be capped off since you will want to use the mx-3 water pump. Same motor.
Chris Malden
MX-3 RSR
MX-3 RSR
- David Witherow
I HAVE ANOTHER QUESTION WHAT ABOUT THE 1.8 DOHC WHAT CAN I USE FROM THE MIATA ON THAT MOTOR
maldo
Same as with the 1.6L. The head has different coolant passages but it can be used, although the intake manifold can't be. Water pump is different as well. Other than that everything can be used. The valvetrain from the '99 head is the best as it uses solid lifters, not HLAs.<P>(don't yell, we can hear just fine
Chris Malden
MX-3 RSR
MX-3 RSR
