323 turbo manifold question
monty73741
Re: 323 turbo manifold question
Post by monty73741 »
yes it will fit a 1.6l dohc i4<BR>jason
Jason Danaher
Please Help Support MX-3.com
maldo
Post by maldo »
Ports are a different design but I am sure you knew that.
maldo
Post by maldo »
Those ports are circular, the ports on your head are ovalized.
monty73741
i'm confused.......<BR>i thought the 87 had the 1.6 dohc....<BR>& it fit on the mx-3 1.6 dohc<BR>jason
Jason Danaher
maldo
Post by maldo »
In both my '86-87 and '88-89 323 parts manuals, that manifold does not exist. He doesn't specify as to where he got it from but it sure isn't NA. I would be a little concerned, ports #2 and 3 seem spaced too far outwards. My B6T manifold is evenly spaced, so is my B6e manifold. The B6e was available in the '86-87 model year but not turbo'd. Port spacing hasn't changed. The ports for the older B6e are round so the model year could be correct. BTW, a shop may be able to hog the ports out but that may reduce the manifold strength and resistance to thermal cracking.
maldo
Post by maldo »
For starters, its cast so I doubt someone spent time building a custom cast unit as they just wasted money. If it were designed for a N/A 323, the person should sue the guy that built it for him. The design is horrible for a n/a motor.
992mmx3
Post by 992mmx3 »
If he told you it was something it wasn't, then don't buy it. There's ways out of it.
-Mark Lathrop
1992 MX-3 RS-T
B6T with some goodies
