compression Test
Posted: September 30th, 2002, 6:06 pm
by Marlon
I did a compression test on my 92 sohc and I got 150 psi. is that good?
Re: compression Test
Posted: October 1st, 2002, 12:27 am
by torpedan
What was the scores from all of the other cylanders? Really you need the results form all the chambers to give a good or bad quote
Posted: October 1st, 2002, 6:51 pm
by rizzy
well my compresioon is low, i think it was<BR>1-90 2-100 3-110 4-120<P>is that still ok<BR>or what<BR>how to fix if it is bad<P>it only has about 130,000 miles on it<P>what should i do<BR>
Posted: October 1st, 2002, 7:20 pm
by Marlon
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Robert:<BR><STRONG>well my compresioon is low, i think it was<BR>1-90 2-100 3-110 4-120<P>is that still ok<BR>or what<BR>how to fix if it is bad<P>it only has about 130,000 miles on it<P>what should i do<BR>
</STRONG><HR></BLOCKQUOTE><BR>mines only got 118 000 kms
Posted: October 1st, 2002, 8:39 pm
by dam2009
since when you have different ratios in cilinders? unless your valves are "little smoked" average ratio for SOHC mx-3 is 120psi .. make sure you take all the spark plugs out...
