More car troubles
Posted: August 30th, 2002, 4:03 pm
Not to worry too much, I hope, but the car died today. I am 99% sure <BR>that it has nothing to do with the rebuild. Here are the symptoms:<P>Since the rebuild, I added a few more grounds using 8 guage wire. I <BR>ran grounds to the block, MAF, alternator and tranny. Since that <BR>time, my battery charge light has been on periodically. I tightened <BR>the belt the other day, no real change. The car is a little rough <BR>trying to start but I have attribute that to the solid motor mounts <BR>causing much feedback from the twisting motor. Today I decided to <BR>trouble shoot, I removed the ground from the alternator as previous <BR>to the rebuild there never was one there. There ground is attached <BR>to the bolt that allows forward and aft movement of the alternator <BR>for tightening purposes. I removed it while the car was running... <BR>at the same time I was adding Water Wetter to the system. I <BR>proceeded to drive to Krista's house (about 3km away). Half way <BR>there, I lost all dash movement --no tach, no speedometer-- car ran <BR>fine still. Even nearer to her home, my S-AFC basically re-started <BR>itself (the same startup screen that appears when turning the car on, <BR>reappeared while driving.). I turned down her street and this is <BR>where things really started to act up. The car started bogging, as <BR>though it was either lacking spark or fuel. The EGTs did start to <BR>climb, car was in 2nd gear around 1500-2000rpm (no boost), hardly in <BR>the danger zone. The car limbed right in fron of Krista's place, I <BR>basically lost everything - power steering and brakes included. <BR>Tried to fire it back up, I was able to acheive a clicking noise <BR>which leads me to believe it is the battery. The charger is on it <BR>now so I will know soon. My other thought was the starter but the <BR>noise that I am hearing sounds like the solenoid is active, just <BR>lacking the power to spin. Any thoughts on the battery charge light? <BR>could be the alternator but I don't see how it goes from working <BR>before the rebuild to not working once things are going.
