INJECTORS
INJECTORS
would it be a good plan to run a fuel management system and new injectores. I want to but dont know what kind to run or what parts i will all need for the process help me please [img]shrug.gif"%20border="0[/img]
Re: INJECTORS
I don't see any real reason to run new injectors if you aren't running any kinda of turbo set up???
Re: INJECTORS
Unless you are running a turbo or SC there is no real need. You will just be wasting your money. If you are building an all motor car, you should concentrate on better mods that will give you more power before you would have the need for more fuel. In any case, this has been mentioned in a previous post on the UBB. The stock ones are good for around 120whp, once you reach that, the Pro LX 230cc injectors can help you reach 135whp safely. Going to limits above what I mentioned brings the duty cycle too close to 100%.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
Re: INJECTORS
How many cc on the stock injectors?
Re: INJECTORS
around 205cc.
Chris Malden
MX-3 RSR
MX-3 RSR
