biggest motor
msatz
biggest motor
Post by msatz »
I need to find out what would be the biggest motor and performance products I could put in my 94 mazda 4 banger. Could any of you guys help me?
Stevech_2001
Re: biggest motor
Post by Stevech_2001 »
Hey man check out <A HREF="http://www.corksport.com....some" TARGET=_blank>www.corksport.com....some</A> other things are ractive strut bar, pacesetter short shifter, Gude cams
Steve
OsoSlo z28
Re: biggest motor
Post by OsoSlo z28 »
turbo.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
mitmaks
Re: biggest motor
Post by mitmaks »
hey i have idea about swapping in small block 350 chevy in my mx-3 in future...upgrading it to around 600 hp car...will need much work but its gonna be worth it.
msatz
Re: biggest motor
Post by msatz »
That would be tight. But is that actually possible? I mean the MX-3 engine space isen't exactly the biggest spot to put a chevy 350 motor. Hey if it works tell me about it and good luck!
rikymaru
Re: biggest motor
Post by rikymaru »
If you put a 350 into an MX3 Im sure the weight balance would be so off it would be undrivable.<P>And you could point to the Monster Miatas, but you know what? Those cars are trailered or if they are driven around they are driven VERY slowly.<P>If your going to mix domestics and imports then get a Datsun 240 or 280Z shell and drop the 350 in. People are running 12's with just the stock motor in.
Elena, don't misunderstand. A pro isn't someone who sacrifices themselves for their job. That is just a fool.
